Author Topic: Kandinsky Light  (Read 19526 times)
Fluke
Kandinsky Light
Version 1.0.3 | Download Link
A light, minimal theme for Musicbee 3.0 inspired by the old Zune desktop player.
You can find a dark version of the skin here. Let me know about any issues you
find or potential changes you'd like to see!
Install Instructions
Place file in your Musicbee/Skins folder and select it in Musicbee under View > Skins.
_____________________________________________________________________________________
Update Log
Jan. 16, 2017 - Changed border images in file to fix issues relating to title bar. (v 1.0.1)
Jan. 22, 2017 - Changed color of star rating in the main panels to match color in player
controls bar. Changed color of check tick marks in Preferences window to match skin
highlight color. (v 1.0.2)
Jan. 3, 2018 - Adjusted star rating lowlight color so that it doesn't stick out against the
background. (v 1.0.3)
Last Edit: January 03, 2018, 07:42:25 PM by Fluke
DarkerthanDreams
download link is not working says "this download is currently unavailable" :-\
Havokdan
Thanks, great skin :), I edited just to use the green color here and it was reasonable (I'm not very knowledgeable).
Fluke
Mind trying it again? I think it might have been some sort of temporary server error, since it looks to be up now.
DarkerthanDreams
yes it is working now thank you!
AvikB
I am currently using MusicBee 3.1 and found two issues:
Titlebar on both MusicBee main window and Preference window has weird issue.
Fluke
Hmmm, are you using a 10pt font? For some reason, I sometimes get something like that when I use the default 9pt font. (It might be a separate issue, but if anyone knows why that happens please let me know!)
Otherwise, I'm not too sure. I'm still using Musicbee 3.0.6190 (the latest non-beta patch from December 2016) and I'm not seeing any issues personally.
hello7i
Hi Fluke! I have a little problem with skin. It's on, but does not work. MusicBee ver. 3.0.6132
I don't use 10pt front, but i think it won't help with this trouble. Can you help me?
UPD: Using 10pt doesn't fix problem
Last Edit: January 15, 2017, 12:17:09 PM by hello7i
Nice work!
BTW border image sizes for both skins need to be adjusted.
The border image sizes should be as follows.
FormBorderTop ------------------------------------------------- 1x28 [pixels]
FormBorderTopRight , FormBorderTopLeft ------------------ 5x28
FormBorderRight , FormBorderLeft  -------------------------- 4x1
FormBorderBottomRight , FormBorderBottomLeft ---------- 4x4
FormBorderBottom  -------------------------------------------- 1x4
  • MB Version: 3.6.9255 P
Hey Fluke!  Your border images are incorrect and is probably the culprit behind the problems users are having with this otherwise great looking skin.
The border elements should be in .png format with a 96 dpi value.
The dimensions should be:
Border Bottom: 4px high x 1px wide
Bottom Left/Right: 4px high x 4px wide
Left/Right: 1px high x 4px wide
Border Top: 28px high x 1px wide
top Left/Right: 28px high x 5px wide
Hope that fixes things.
EDIT:
Oops! redwing posted and I was still typing  :o
AvikB
Hmmm, are you using a 10pt font? For some reason, I sometimes get something like that when I use the default 9pt font. (It might be a separate issue, but if anyone knows why that happens please let me know!) Otherwise, I'm not too sure. I'm still using Musicbee 3.0.6190 (the latest non-beta patch from December 2016) and I'm not seeing any issues personally.
no i am using a lots of custom font size for different panels.
Maybe it is a issue with v3.1, can't really say. :)
Fluke
Thanks all for the helpful replies! I'll try fixing my border images and will roll out a patch soon for both the skins. Hopefully will fix the title bar errors.
UPDATE: I've changed the border images and updated the download link. I must have misread the dimensions on the wiki, since all of the border elements were rotated in my initial skin (e.g. 4x1 instead of 1x4 pixels). Thanks to Bee-liever and redwing for taking the time to find out what was wrong. Let me know if that resolves the issues you guys were seeing!
Last Edit: January 16, 2017, 06:04:48 PM by Fluke
Fluke
Thanks for the comment! I think checking the "Skin Windows Borders" option under View > Skins should make the changes you're looking for. I also recommending downloading the latest version of the skin to (hopefully) fix any remaining errors with the title bar. Let me know if that works!
Last Edit: January 16, 2017, 10:09:43 PM by Fluke
