Many thanks.
if you want to group files by folders
I am not quite sure, I want to sort the folders (e.g. newest / last added folders on top, by alphabet or else) on the left side and display the music folders only.
Whatever I click here, "All Artists" keeps staying like it is:
You can find that option by right clicking in the column headers.
Yes, but I am not able to sort the folders like I want.
You can create a custom sorting set in the Sorting/Grouping page of preferences.
Yes, I had done without success.
The computer node is in the left navigator panel, which as mentioned is probably hidden and will pop up when you mouseover the left side of the window.
Yes, but it does not work anymore / at the moment:
Yes, OK, thank you very much
