Author Topic: Default Relayout for Synced Lyrics  (Read 10826 times)
NicoVIII
Hello everyone,
I use MusicBee now for quite a while and I love the TheaterMode.
Because I'm quite obsessed with synchronised lyrics and my whole library has them, I wanted a layout, which focuses more on them. So I took the default layout and built this.
This layout is made for 1080p Displays. I'm not sure how to create it for multiple resolutions.
I'm not a designer, but I hope you like it ^.^
(and it's okay that I put the renamed default image in the archive as well)
Download:
http://www.mediafire.com/file/lfc0ix8p4t2fy5t/Default_sync_lyrics.zip
Last Edit: December 06, 2016, 01:28:29 PM by NicoVIII
The Tim
Nice! Do the lyrics auto scroll for you? I installed but I can only manually scroll the lyrics.
Do you have synchronized lyrics with timestamps in them?
Freddy Barker
  • 🎧 MB 3.4.7628P
frankz - Are there any plans to add a filter to be able to select only download for 'title.lrc' lyrics please?
I like what you've done so far with reloaded plugin!
Freddy
What providers do you know of, other than Minilyrics that already has a plugin (and a website that currently doesn't appear to work) that provides synchronized lyrics?
The Tim
Oh yes, all working now. I think I was entering time stamps incorrectly last night (first time using the function), did it fresh today and it appears to be working perfectly.
Thanks!
Freddy Barker
  • 🎧 MB 3.4.7628P
None providers spring to mind, other than Shazam and the ones listed in the options in your new reloaded plugin,  but of those listed, is there no way auto-embed ONLY lrc lyrics if found of the currenly playing track, and skip over the text only lyrics?
Freddy
