Author Topic: Can you set multiple hotkeys for the same action?  (Read 2407 times)
Pwalex
Hi there,
I just discovered MusicBee and fell in love with it. The design is just pure simplicity, and I love how powerful it's customize-ability is as well.
I only have one little issue, however, which is that it appears that it's only possible to assign one hotkey to an action. I find this somewhat limiting. I want to have the default play/pause to be spacebar (like almost all media players), but also have a global hotkey for it that I can use in other applications without causing a conflict. Is there any way to make this happen?
Thanks very much!
Have you ticked the 'global' box to the right of the hotkey assignment?
Pwalex
Yes I have, but that's not the issue. The global hotkey works, but I want to also assign another, non-global hotkey to the same action (play/pause in this case).
That can't be done.
Although I'm curious as to why you'd want it duplicated.
Pwalex
Because I want to set a global hotkey, but pressing Crtl+Shift+Del every time I want to play/pause while I have the application open is annoying, and defies my instinct to just hit spacebar. But of course, setting spacebar as a global hotkey for play/pause is not going to be feasible. I'm surprised this is such an unusual thing to want. Sure, it's not for everyone, but I'd be surprised if I was the only one who wanted this feature.
salt
Late response but as far as I can tell
Multimedia: Next             does the same thing as  Playback: Play Next Track
Multimedia: Play/Pause    does the same thing as  Playback: Play/Pause
Multimedia: Previous       does the same thing as  Playback: Play Previous Track
and in this way I have set both global and local hotkeys for previous, pause, and next.
