Author Topic: where is the Skip Silence setting?  (Read 2943 times)
movebetter
where is the Skip Silence setting? I dont see it under Preferences - Player. I want to be it is disabled.
CritterMan
  • Now with FiiO M11!
Ctrl+O > Player > 2nd from the bottom - untick the box and don't forget to save your changes.
CritterMan
The setting is cut off at the bottom along with several others. It looks like you are scaling way up, and that's likely causing the issue.
Moderators: Perhaps this should move to bug reports.
movebetter
CritterMan
