I'm just switching over from iTunes and love Musicbee. But something is weird. I did take the time to remove all comments I had in iTunes a while ago.
Now opening my music files in Musicbee old comments that I definitly removed are reapearing. And whe I simply listen to a file and then go into iTunes the comments also start reapearing in iTunes.
Is there some Id3Tag v1 => v2 conversion going on I don't know about?
Should I uncheck "also save ID3vv1 Tag" in settings and the old comments will dissapear?
Kind regards
