I have a proposal/wish to make it a lot easier to make use of the new work/movement feature.
When selecting to use work/movement for a track(s) in the tag editor, for tracks that don't have the 'work' and 'movement' tag frames populated yet, these tags show up empty.
Then next you will have to fill them yourself by doing (a lot of) copy/pasting.
I have a proposal to make this a lot easier and user friendly:
There already is a consensus on how the title of a classical track should be constructed.
It has been good practice to have the title containing all available information, including the work, the act, the movement, the section, etc, and having these items separated by agreed-on delimiters.
So the title of a classical track would look like this (for a track that does contain most of these items) :
the name of the work it belongs to
then a comma , after which the catalog number (opus#, BWV###) and/or it's sub-title.
then a colon : after which the name of the composition
then a hyphen - after which the name of the section or movement*
(* note that this 'movement' is not identical to the tag frame also named 'movement')
It would be great if MusicBee had a button in the tag editor, that when pressed, auto-fills the tag frame 'work' with the string before the colon delimiter, and the tag 'movement' with the contents after that colon.
To any classical aficionados reading this, please check if I indeed have this all correct, and feel free to chip in if you think I am making any wrong assumption here.
