Author Topic: "Show highlighting" How must work this function?  (Read 3796 times)
Sofocl
How must work this function, or it is not ready yet?
Sorry for my bad English.
it should show the highlight color on the top right of the matching albums. Trying now i see it doesnt work if an icon is also used, so remove the icon and it should work
Sofocl
Was not able to achieve any result:
3.1.6143
Sofocl
Maybe somebody from the forum members can simply show a screenshot of how it all should be working \ look like?
  • MB Version: 3.6.8878 P
using latest patch 3.1.6143.39573
and icon highlight override is working for me
would be good if the icon/highlight also showed in the expanded panel
Last Edit: October 27, 2016, 11:18:33 AM by Bee-liever
Sofocl
Thank you for helping Bee-liever.
Figured out, here's the problem:
Looks like this function needs some tweaking in 3.1  ;)
i put in some handling for when "fit to panel" is not enabled
Sofocl
Thank you Steven, it's fixed.
But a new problem:) covers disappear with icons;
that should be fixed for the next patch update
Sofocl
