Author Topic: A-B Looping/Repeat  (Read 4844 times)
DiaborMagics
Hello there,
Correct me if I'm wrong, but MusicBee does not have A-B looping/repeat, right? So setting a point A after say minute 1 and B after minute 2 and it will loop between minute 1 and 2 until you stop it?
Thanks,
DiaborMagics
Several ways to achieve that.
- Set start/end time in tag editor> settings tab
- Use Bookmarks node (search the forum for details)
- Use Track Previewer plugin
For repeating, adjust repeat setting on player bar.
DiaborMagics
Alright thanks I will check it out.
I was not thinking of something like editing the tags, because it's not very 'dynamic'. I remembered this functionality from an old MP3 player I had and I could just go to a point, give it an A, go to the next, give it B and it would repeat. If I wanted to select a different part, erase, new A, new B. This is what I mean by dynamic. Since I know nothing about the 2 other points I'll investigate on those, certainly.
Thanks a lot for the tip!
Bookmarks will probably come the closest to what you're thinking of.  You just use a hotkey to set a start and end bookmark, and then you can play the bookmarked section from the Bookmarks node as its own track.
DiaborMagics
Aahh thank you, I will definately check it out!
