Author Topic: Ability to disable drag and drop tagging.  (Read 10330 times)
krissasaur
I am not sure if related but ever since I patched it, when I try to edit tags in Musicbee with the right click > edit box I get this error.
Also it isnt open in anything else. I tried restarting my PC even. Also, it sometimes will change the tags anyway.
could you run this version and it will log a more detailed message in the error log when it next happens
help/ support/ view error log and send me the information at the end of the file
alec.tron
Since I've never come across this - can anyone explain this feature ? or is there a wiki page explaining this in more detail ?
From what I see when trying around with this, this only works in the column browser and only for Artist metadata (I assume a historical convenience function for unifying mixed Artist spellings/variants easily...?) or is this functionality adjustable to other/more metadata ?
Cheers.
c.
theta_wave
Cheers.
c.
I was in the same boat; I never knew the existence of this feature prior to this thread.  Basically, if you drag files to a column, the respective field of those files will be updated to whatever value you dropped them in.  For example, say you want to have a group a files to have the same year (say, 1999).  Instead of selecting them and pressing shift+enter to open up the tag editor (like I would), you drag those files to the Year column, drop them on "1999" and press okay.  Now, the value of <Year> in all of those files will be "1999".
Conversely, if you were dragging and dropping files to fill a custom playlist on the left sidebar and accidentally released the mouse button while hovering over one of the column fields (and absentmindedly pressed enter to confirm), you'll be left with a pile of files with the same value as whatever column you dropped them in.  Then again, there's an undo command.  But it can get annoying if one is creating a bunch of custom playlists after opening MB for the first time.
alec.tron
Hah, thanks for your take ssri!
Dragging from main library list onto a column browser value/entry makes more sense... I only tried selections from a column browser field to another column browser field and that didn't make much sense (other than when all miss-labelled Artist-names share the correctly named album name or vice versa)...
I think I'll stick to Shift+Enter too though, but good to know this exists as well.
c.
krissasaur
Hope this is what you wanted!!
2016-10-29 10:22:56 PM - 10.0.10586.0 - 3.1.6146.41074 - System.IO.IOException: The parameter is incorrect. [Z:\My Music\!English\D\DragonForce\DragonForce - 2016 - Album - Killer Elite\DragonForce - 2016 - Album - Killer Elite - 07 - Fields Of Despair (Live).mp3]
   at #=q5KcWmK4KUeemk2qw_0157Q==.#=qOWQc_DoMJRurGEj7Ujm$bg==.#=qrLl0FGE717hBGGt2WNX7pQ==.#=qcLwphfUhJnZnkUpCQcPhRIAGjJoxPJ0fOIiHm4EZUBI=(#=qivduWORY17zX7fbHtSw3vA== #=qtALxhqgN95u2eKRPBSrUKA==, #=qo2sZu2JX1opwW8jGekwhSA7z2L0tcuyFY8N4YH_RqwQ= #=q_3U0uIx1Z_PLBQQM_EanSA==, Boolean #=qaonis7cvV_R0otN9aHihaA==)
   at #=q1ypf2P6_670GkulQCjnUPo9lNLMeWKqnVbQuQFa9OU8=.#=qBLXZq1Z_EuWvYCDtKjcvjQ==(#=qivduWORY17zX7fbHtSw3vA== #=qOOhlKEZ3coA_XfSfTfgCsg==, #=qo2sZu2JX1opwW8jGekwhSA7z2L0tcuyFY8N4YH_RqwQ= #=qn4T0Dh8AS3k3p8bLMiSrQg==)
   at MusicBee.Media.StorageManager.#=q8N7VEVgYbIdE372kc74yRA==(#=qivduWORY17zX7fbHtSw3vA== #=qcp6JhZs59Bgf8b6j$P2GTQ==, #=qo2sZu2JX1opwW8jGekwhSA7z2L0tcuyFY8N4YH_RqwQ= #=qAzAdXZLsD0IoyJ7MRO$LTQ==)
   at #=qIAiqtO7tv9EjhIrSU4Grrsc37jNS8ia18BxrkcvGoYw=.#=q$MsKgvPB2DQliALfgt0VAQ==.#=qtATL9jZavyWLmxWuf4N38Q==.#=qhU9ZTtR7sgdlAulhAAW9GNkxQwipAlyEMzvSyzDkCC4=(#=q8B6qsukErZMtIeiiQHZaGDIOc4Cu0UbMhvGfEAyHmyA= #=qHb4$csOJ4Et1PaCIfECZSA==, List`1 #=qBuj5jXJr5k5huGk0L9pqgA==, Boolean #=qsiiRKAoY7fuOOKYwtpfP1w==, List`1 #=qss7VyMJk7dxRNIER2WG5Rw==, #=qL6bCR4ibJqBxPmb1fykYRmiWpjE3jigLKQw9juSR0xE= #=qGz2OGgIF1tQtBH9f28PZMg==, Boolean #=q$Ob_iwhkURSOi1fRk8j3nw==)
   at #=qIAiqtO7tv9EjhIrSU4Grrsc37jNS8ia18BxrkcvGoYw=.#=q$MsKgvPB2DQliALfgt0VAQ==.#=qtATL9jZavyWLmxWuf4N38Q==.#=qbBNtbChy5cjiw$m3W9gfTQ==(#=q8B6qsukErZMtIeiiQHZaGDIOc4Cu0UbMhvGfEAyHmyA= #=qYreFON7HhnOreXIj$C6Jcw==, List`1 #=qzkyQ9Rv5o_KzDMysy7HG$g==)
   at #=qIAiqtO7tv9EjhIrSU4Grrsc37jNS8ia18BxrkcvGoYw=.#=q9GBBJDa3CG$GkColy9ZjmQ==.#=qxDZaGGtKoXXrF$_uQelihw==(#=q8B6qsukErZMtIeiiQHZaGDIOc4Cu0UbMhvGfEAyHmyA= #=q2Sv1brOWpokmvf46R1zN0w==, List`1 #=qsC6ZmhA8dE$KlgMOVboWXg==)
   at #=qIAiqtO7tv9EjhIrSU4Grrsc37jNS8ia18BxrkcvGoYw=.#=q_61gPgn0wnujpcLr4Uej2g==(#=q8B6qsukErZMtIeiiQHZaGDIOc4Cu0UbMhvGfEAyHmyA= #=q7cNiC22cHMTKsedISiFSFg==, List`1 #=qZVy1M3Hu1$v_glpHRG3D0w==)
   at #=q1ypf2P6_670GkulQCjnUPo9lNLMeWKqnVbQuQFa9OU8=.#=qALOX50hwJuQpQaDbnkhsMA==(#=q8B6qsukErZMtIeiiQHZaGDIOc4Cu0UbMhvGfEAyHmyA= #=qZUV0opm0jwnM0mzv$Rdqyg==, List`1 #=qeHTWiPAP9tcos1d3p28mBA==)
   at #=qiLKxo0Pg0rsFpPlnTF23gFBzE59$jJHq2nIYQBycH1I=.#=qbFd2qbCrHm0yatyBns1FhxiHpBoM5e2mHqlOLWWyEkw=.#=qz2f4XF9PygUgyQrtoDGM8g==(#=q6v$QvFfFXcqJmq$T3DKD2675jinlKL1Z9UBPHzcvAPhvsSUeZVx4g2u7_9760845 #=q6anbteDmXZ4JSvsW$0xx3g==, Boolean #=qfpwKwi$KwbLQIh5c3wAVJg==, List`1 #=q0vpAmgyzFWOfmV_qgOit4A==, List`1 #=q_qmnIuxKvdnJHtNenWwlPMuiPP0SpwD9GY_hffYbQEM=)
You problem could be one of two things (or both.)
First is you have a very long path - 154 characters. Windows has a limit, but I can't recall what it is.
The other is the "!" in your path. I'm not sure if that character is allowed in file names/folders/paths.
Or I may be wrong on both. :-)
theta_wave
Max path is 260 characters with Windows API (although in practice, it is more like 255 characters).  Also, exclamation marks for folder and file names are kosher with Windows (http://www.techrepublic.com/article/force-your-favorite-files-to-the-top-of-any-directory/).  They are a pain to work with if you mount the drive on linux though.  That is why I just use "0_directory name".  Then again, for some reason, .net programs like cuetools place 0's at the bottom of the list (like in real life I suppose).
krissasaur
Thanks for the response. I doubt this is the problem as I have had this set up for about 10 years now, unless it is a Musicbee specific thing with filenames. It also only started yesterday. (Or the day before, by now, I suppose.)
MB 3.1 has support for long windows filenames (that wasnt the case in older versions), so the total length can be <32,767 and each individual directory folder name or filename <255 chars.
There was a bug with the preservation of the file modification time when that option is set. Thats fixed now:
krissasaur
Still happening:
2016-10-30 9:38:37 AM - 10.0.10586.0 - 3.1.6146.41074 - System.IO.IOException: The parameter is incorrect. [Z:\My Music\!Japanese\D\DADAROMA\DADAROMA - 2015 - Mini Album - dadaism#1\DADAROMA - 2015 - Mini Album - dadaism#1 - 03 - MONEY.mp3]
The weird thing is it still retags the files if I hit X or cancel.
krissasaur
Still happening:
you arent using the version i uploaded
Ah sorry. I think my date modified was being weird. Sometimes I need to f5 to get the most recent download to appear at the top so I probably did that. It seems to be working fine now. Thank you!!
