Author Topic: Window position reset on left snap  (Read 1601 times)
skyvory
Is it just me or MusicBee window reset itself to top left position after close and open if I snap it to the left side of the screen.
There's no problem if I snap it on any other side.
I'm using version 3.0.6132
there is a small bug with snapping to the left of the screen when using windows 10. This should fix it:
unzip into the folder MB is installed
skyvory
Nice fix!  :)
Works perfectly.
Avast doesn't trust the .exe though. Maybe due to unknown publisher.
Avast is known to not get along well with MusicBee in general, unfortunately.
