Author Topic: Unable to select SD card as the storage location : Samsung J7  (Read 3109 times)
stimpi
Hi - I am unable to select SD card as the storage location for syncing files from Music Bee. Both Win10 explorer and the Devices tree in Music Bee can see the SD card, but the SD card location is not available in the storage location under settings for the phone.
Can someone help with this please?
Settings screenshot
Device tree screenshot
wumple
Hi, I am trying to follow the instructions here but it is not working for me. I am trying to direct musicbee to an Fiio M7 sd card. The issue  might be that the M7 is showing up as D:\ in musicbee but I can't navigate to the sd card from D:\ . In windows 10 the path name is This PC\FiiO M7\M7 Micro SD. I'm not that experienced technically so the issue might be me :), hope someone can help. thanks
antidoteyymbr
@wumple
Hey so I just upgraded to an M9 from an X1 so as you know I was quite pissed with the implementation of the terrible protocol that is MTP. The workaround that I have, if you can just buy a microsd to USB adapter for your computer and sync it that way (unless you already have a built in card reader). as long as it is formatted for the Fiio, the computer doesn't know the difference and will sync.
 I did this fairly easy since I just used the sd card from my X1 for my M9. Just make sure that the M9 is completely powered off when you take out the sd card, and make sure you don't power it back on until the card is all the way plugged back into the M9. Otherwise, the m9 won't recognize the card and will want to update all the songs again, which takes hours (if you have 17000 like me).
Like i said it is a work around, and probably the best option, since this is a MTP issue and not a Fiio issue that we could ask them to implement in future firmware. Only downside is forgetting to put your SD card back in the M9 before you go to work for the day!  ;D
