Author Topic: gabriel martins  (Read 934 times)
gabrielmartins
 :)      hello good people of the music bee. I'm from Brazil and like all passionately collect songs etc ...
I would like to know people what happens with the default music folders windos I added. all are empty including the default music folder created by the application. I know there must be a clear answer. pesse apologize for the lack of knowledge. I looked for an answer on the site but so far have not found response. who can enlighten me or send a link I'm grateful.
Sounds like your music files were moved to another location. It could be MusicBee or other applications like iTunes depending on organization settings.
With MB, that can happen if you have enabled either "auto-organization" or "automatically sweep and move new files". Both settings are located under Edit> Preferences> Library.
But MB removes empty folders after moving files, so I suspect it might be another application.
