Author Topic: Changes for version 3.1  (Read 41492 times)
vincent kars
I would appreciate a better handling of classical.
This means MB should be aware of the concept of a composition.
Basically this is the same as an album, a couple of tracks having the same value in a “composition” tag.
A "simple" solution would be that one can swap Album Name for “Composition” in Preference > Sorting/Grouping > Grouping
Smart sorting would be appreciated as well
Sonate No.1
Sonate No.10
Sonate No.2
Is  very inconvenient but inherent to an alphabetical sort
Sonate No.1
Sonate No.2
Sonate No.9
Sonate No.10
Is what we need when sorting classical
i am happy to look at making improvements for classical music handling
+1!
Sofocl
+1
Sorry for my bad English.
brx
I think that the sound is enhanced in this version, which is a good thing, sounds fresh or I'm overreacting... :)
Btw, drag n drop is not working anymore or I'm missing something...
Last Edit: November 20, 2016, 01:24:23 AM by brx
nadash
I want to see development and improvement. Because your progress Like our development. : :)
Dpmusicbee
Appreciate the hard work Steve. i like to know where i can find the lateest 3.1 link and patch link for it. i have looked all over this site and can't find a direct link to 3.1
Thank You
CritterMan
  • Now with FiiO M11!
A search for 3.1 patch finds it fairly quickly. http://musicbee.niblseed.com/V3_1/MusicBee31_Patched.zip
Chaython
[What I want in this release] crack and fully support apple m4p [without conversion] ;)
The latest MusicBee patches.
Maxxx
My desire. In the edit panel more space for the comments field. You can move year-track-drive on the left side, below rating album.
Thanks
Dpmusicbee
orbittwz
Hey!
Just noticed the beta v3.1 version and immediately updated my build :)
First, the bass is great, i noticed it right away, and the separation between the stereo mixers, the sounds are crispier  :-*
Thank you very much, i will never switch to another music player again!
Some observations:
1.
When '1' is checked, field '2' will not be displayed anymore.
It would be good if that field was greyed-out then.
2.
For this layout, in the Album and Tracks layout panel I make no use of the 'Album' tag directly. (only by means of virtual tags)
Yet there will still be a column named Album.
That can be confusing, and it also prevents the option to deliberately set an actual 'Album' column.
3.
When analysing and writing loudness normalisation and have 'on album basis' selected, and you have the new 'movement' feature enabled, for those tracks normalisation will not be done on basis of 'album', but on basis of 'work'.
I do agree with that choice. But the wording in the panel might reflect that to prevent confusion for some.
(or perhaps make it a selectable option)
