Author Topic: Changes for version 3.1  (Read 41724 times)
Would this be a bad moment to suggest for the installer to include the option to either do a 'full' install, or create a portable installation?
thanks for reminding me. Its in the lastest version topic but not possible on the downloads page
Not sure we're on the same page here.
I meant that there is only one installer, which after executing it, presents the option to continue installation either as a full install, or create a portable install.
Sofocl
+1
Sorry for my bad English.
Then show left navigator with all nodes expanded so that drives and folders will be visible.
yes i agree with that
I just tried v3.1 RC1 and found left sidebar still auto-hidden. Did you change your mind again?
i only changed it so the computer node is now expanded by default. I dont plan to make the left navigator open by default
