Author Topic: Minor cosmetic "localization" issue  (Read 1630 times)
MeeMeeMee
So because of some app that didn't handle correctly my local settings I was forced to change some of my regional/language settings, namely the date format for a few weeks till that app's issue was sorted. In the meantime, I kept on downloading podcasts and ended up with a podcast list that looks like this:
http://imgur.com/r91rgCQ
Edit: I tried embedding the screenshot but failed misserably. Is the img tag broken?
Edit2: OK, I had to manually add ".jpg" to the URL and it works.
Last Edit: September 19, 2016, 07:37:04 AM by MeeMeeMee
MusicBee 3.5.8516 / Windows 10 (64-bit) / Intel i5-3470 / 8GB RAM
Media on NAS (CIFS share)
Get the latest patch: https://getmusicbee.com/patches/
works fine for me, example:
[url=http://www.mediafire.com/view/8eauww9wiufuh1w/temp-1.png][img]https://www.mediafire.com/convkey/2e02/8eauww9wiufuh1w4g.jpg[/img][/url]
result:
