Author Topic: "Add to Playlist" auto-closes the Expanded Panel tracklist  (Read 1887 times)
zillatron
Hi there
Loving MB so far,
however every time i perform the action "add to playlist" on a track
the Expanded Panel tracklist (in the main panel) is immediately closed
but only if it is set to be shown "directly under the selected album"
(if tracklist is set to bottom of main panel it just adds to playlist as expected)
Additionally performing Add to Playlist from the Playing Tracks on the right side-bar
will also close any (unrelated album) expanded tracklist in the main panel
Is this normal and/or any ideas on how to prevent this behavior?
thanks
i cannot reproduce that behavior or see any reason for it.
If you send a link to your settings (help/ support/ view settings) i will take a quick look
its probably related to having "playlist" displayed in the expanded panel but i wasnt able to reproduce the behaviour you describe using your settings.
I suggest you update to the latest patch version from the first forum topic
zillatron
confirming this issue is now resolved after applying the latest patch
many thanks!
