Author Topic: select library on programm start  (Read 2494 times)
gyrogearloose
hi,
Can somewhere write me the shortcut to start musicbee with select library dialog?
In past it has work, but I forgot the buttons. I tested it by start with strg+doubleclick and shift+doubleclick but nothing works.
Thanks for help
Gyro
Hold the shift key down while starting MB.
Once the dialog opens there's an option to "always prompt for library selection when MB starts"
gyrogearloose
thank you. It works. I don't know why it works now .....
