Hello Steven and thanks for the response,
You see, this is the largest part of the problem I have been experiencing with Machine A and opening MusicBee as Administrator.
If I try to open MusicBee as Administrator, (right-click on MusicBee.exe file,) MusicBee simply will not open.
It is really kind of a strange occurrence for me.
I honestly have never experienced an application that would not open when using the right-click, enabling Administrator.
However, I have been thinking back to when MusicBee was re-installed a few months back with a clean install because of other issues.
The re-install cleared up those particular issues, but maybe my mistake/or not, when I re-installed, I run the installer as Administrator.
There are a couple of other programs on Machine A that I have used the right-click for Administrator, and they open as they should, but
they were not installed with Administrator permissions.
Just thinking here, would that possibly cause the right-click to not work in MusicBee, therefore not opening?
If so, should I uninstall and reinstall over once again?
Also, if you do change the location for the equalizers to the AppData folder, what/how will that change things for us on the users end?
Thanks again!
