Author Topic: Can't rip a CD  (Read 2463 times)
stryker84
It's not a commercial CD, rather a "home-made" one from a street artist.
For this particular disc, I click on Rip CD, but no tracks show up, therefore none are selected, and the Start Rip button is greyed out. However, in the main MusicBee player, there are 5 cda tracks shown, just not in the rip CD pop-up.
Salamander
I have exactly the same problem...
Anyone??
CritterMan
  • Now with FiiO M11!
No clue.
But, I've used this software for ripping and it uses AccurateRip as well. You can use the same offset as you do for MB. Might work, might confirm that it's a disc/drive issue and you'll need to try a different drive.
http://www.exactaudiocopy.de/
And some useful links: http://wiki.hydrogenaud.io/index.php?title=Category:EAC_Guides
Salamander
thank you very much - it worked perfectly with this other program!
