Author Topic: Portable Version gives corruption error, then entire directory is gone?  (Read 1489 times)
dannylee11
I was listening to some music today, when suddenly my musicbee crashed.  I went to restart the program, and my theme and everything had reset.  Then is crashed again.  So i restarted my pc, and launched MusicBee again, and it gave me a corruption error.  Not a big deal, except all my custom playlists were in there....  And now, all the files inside my MusicBee Directory are gone!?  Why would they disappear?  I cant open musicbee because now there are literally no files or folders in the MusicBee Directory?  How can i get them back??  Why would it delete itself?
Last Edit: August 21, 2016, 02:52:54 AM by dannylee11
it doesnt. I would say your computer is failing and you should raise these sort of questions on a windows forum.
Another possiblity is your security software is doing something. If you are using Avast with the deepscan feature enabled then that is known to cause issues with MusicBee
Last Edit: August 21, 2016, 08:02:56 AM by Steven
