Author Topic: [FIXED] Compact player: Configuration does not retain stack* checkmark.  (Read 1583 times)
theta_wave
MB 3.0.6073
Skin: DarkRed Flat
I started using compact view the other day and have been noticing quite a few visual bugs.  So, here's another one ;)
Steps:
1) Switch to the compact player
2) Musicbee dropmenu > Customize panel
3) To the right of the checked-off track information element, check the box under the stack* column
4) Hit apply and save
5) Go back to the customize panel and the stack* column next to the track information element is now unchecked.
This is what happens after performing steps 1-4 and then restarting MB.
Last Edit: August 21, 2016, 04:29:00 PM by ssri
theta_wave
I forgot to report that the posted build fixed this issue.  Thanks Steven :)
Last Edit: August 21, 2016, 04:58:20 PM by ssri
