When I try to sync my 100+ playlists I miss the option to check ALL playlists IN COMBINATION with the option to DE-select a few. It is all or nothing. Please KEEP the separate checkboxes in front of the displayed playlists once you select ALL, so that some can be de-selected.
Now the boxes disappear if you choose for ALL.
