Author Topic: Report Website related bugs/issues here  (Read 134278 times)
KylePolansky
When in "Rip CD" Popup, clicking on "Settings" button without lame.exe will pop up message:
MP3 encoding requires LAME.EXE which cannot be distributed with MusicBee due to license restrictions. However you can download LAME for personal use - see http://www.getmusicbee.com/help.html
This URL does not work. I believe the correct URL should be: http://getmusicbee.com/help/faq/
While the help URL text can be changed in future releases, I would recommend adding a redirect on the website so that older versions of the software are pointed to the correct location.
Side Note: I love the new website design!
AvikB
Hi KylePolansky, thanks for reporting the issue. Currently there are no redirects from the old website. I will fix this issue asap(maybe a day or two).
:) thanks.
AvikB
First of all this is a bug report thread, DO NOT POST REQUEST HERE.
Things to keep in mind when posting bugs:
  • For critical security related issue, DO NOT DISCLOSE THE PROCEDURE TO RECREATE THE ISSUE!, i will get back to you via PM.
  • If possible please attach screenshots showing the issue.
To post an issue click on Reply and post in this thread directly. No need to create a separate thread.
Last Edit: August 15, 2016, 12:11:41 AM by AvikB
i have posted a patch from avikB that should address this
In the dark theme, locked posts are not dark:
Two things related to add-ons:
1) The add-ons page uses my official username rather than the display name I use on the forum.  For consistency, it should use the same as the forum (preferably in the URL, too).
2) How do you edit your add-ons once they're posted?  I'm probably overlooking it, but I can't find a way.
Last Edit: August 16, 2016, 01:28:34 AM by psychoadept
On some pages, the menus don't drop down correctly, causing them to pop up and block other menu items:
Go to the Dashboard and select 'view all add-ons.' You'll see them listed on the right side and each one will have an edit icon and a delete icon.
Found it, thanks.
AvikB
noted. Will be fixed in next patch.
Thanks for reporting this. Fixed for next patch.
This is because of javascript error in SMF. I will fix it. Can you give me page urls where it is happening.
AvikB
Thanks.  Do you still need page URLs for the menus?
AvikB
If you find another page where menu is not working, then yes. otherwise not necessary.
Last Edit: August 16, 2016, 08:25:51 AM by AvikB
Well, right now it's not working on this thread: http://getmusicbee.com/forum/index.php?topic=19360.msg115925;topicseen#msg115925
I did a force refresh just to be sure.
Edit: it does eventually seem to have sorted itself out.  False alarm?  I'll keep an eye out.
Edit 2: no, it did it again as soon as I saved this post. *hands*
AvikB
Well, right now it's not working on this thread: http://getmusicbee.com/forum/index.php?topic=19360.msg115925;topicseen#msg115925 I did a force refresh just to be sure. Edit: it does eventually seem to have sorted itself out. False alarm? I'll keep an eye out. Edit 2: no, it did it again as soon as I saved this post. *hands*
Weird working fine here. What did you mean save this post? did you use quick reply box at the bottom?
