Author Topic: Clicking on album art action should be customizable  (Read 2261 times)
Nokiaman
Clicking on album art should be able to do more than this popup thingy
https://i.imgur.com/VZXOdG8.png
It should also to customizable so you can do these
- The songs display on right-most tab where the Star Wars songs are
- The songs are shown in new window like WMP.
- Anything else
It's my only pet peeve with MusicBee as the popup thingy sucks for huge albums.
If you open view configuration panel for the view, there's an option to show the album track list at the bottom of the main panel instead.
Also note that "playing tracks panel" where your Start Wars tracks are is meant to list only tracks that are queued to play.
Nokiaman
Can't find it yet. I am not sure where that should be.
Yes I realize that :/ . I mean the position itself. This panel is useless thus it could be used for that.
Last Edit: August 07, 2016, 10:20:52 AM by Nokiaman
Right click on the view name "Albums" at the top of the main panel and select "Customize Panel..." item.
Nokiaman
Ah I see it now. I was there too, but noticed it just now when you said so. Too bad this still isn't good enough. I need to move it to right :(
It wastes too much vertical space now.
