Author Topic: Get MusicBee to Check For Updates - Manually and at StartUp  (Read 3470 times)
Scorsone
Is there a way to get MusicBee to check for updates and/or manually have it check for updates?  I found the check box that if checked it will look for an update when you open MusicBee.  I closed and then opened MusicBee but said no to the update as I was trying to familiarize myself with the interface.  When I closed MusicBee and then opened it again it is no longer showing the update as being available.  I've unchecked and checked the box and nothing.  Will it wait until the update comes around again or something?
Is there a way to get it to manually look for any updates?
See the Latest Version topic on the forum.
