Author Topic: Pop-up to display dropdown menu items which have been cut off.  (Read 2201 times)
sleepless
Often in dropdown lists the items are cut off and can't be read because the list is too narrow. I would like to see some sort of pop-up to display the full text.
(Or any other solution that works)
Here's a menu in the playlist editor. I can't tell which view I'm selecting because the text is cut off:
Here's an example of a pop-up to read full text in the main panel. I thought something like this could be a solution for the above problem:
Pingaware
+1
