So... since my ask for a generic XML export is a "wishlist" item, I present a bug. I don't see a way to attach a file, so I've put the file here:
https://owncloud.eicat.ca/index.php/s/Dq1ZQP68QKQTuBT... it ends like this:
<dict>
<key>Name</key><string>000-limp_bizkit-the_lowdown-2cd-2011</string>
<key>Playlist ID</key><integer>52300</integer>
<key>Playlist Persistent ID</key><string>F7CABFD834E41101</string>
<key>All Items</key><true/>
<key>Playlist Items</key>
<array>
... which isn't valid XML. A python XML parser also complains that it has a non-ASCII character in it and emac's XML parser complains about a single quote on the first page.
I don't have itunes, so I can't tell if this passes itunes, but it strikes me that it doesn't.
