Author Topic: shortcut for 'send to virtual device'  (Read 1399 times)
I might be mistaken, but I am pretty sure that older MB versions had the option that when you had created a virtual device, you could create a shortcut to 'send to' that virtual device.
I believe that option is gone now, and I would much like to have it (back).
i dont see it in v2.4 or v2.5 and dont recall having support for it.
In any case there would be an issue for people with multiple virtual devices. Having said that i can understand this request would be wanted by people so i will look into it at some point for v3.1
this is done for v3.1. It applies to any device, not just virtual devices and will send the selected tracks of the in-focus panel to the device.
If there is more than one device active then MB will prompt for a device to be selected, which will then be automatically selected until the device is no longer active or MB is restarted
Last Edit: July 10, 2016, 10:01:49 AM by Steven
