Author Topic: initial library scan after install not good  (Read 1236 times)
nomad062
Using Win10. Loaded musicBee 3.0.5995. Entered a directory for it to scan on first startup that contains 300+ artists/album/tracks. Musicbee found 3 of them and nothing I've tried will get it to load the other files except loading them at the track level.
Any suggestions? The drive with the files is just a regular drive although not C: no idea if its means anything but all the artists/tracks picked up are the directories from V on.
Might the "missing" tracks be in the Inbox?
nomad062
They certainly would be ;) lol. Why would some load straight in and the rest go to inbox?
You probably have auto-organize enabled and some tracks are properly tagged while those that wound up in the Inbox were not.
