Author Topic: How to completely remove a wrong track rating?  (Read 5663 times)
WimYogya
I hardly use track ratings, in fact only for 4 or 5 stars.
But sometimes, while editing in the edit box, I click the rating stars by mistake.
In such case I can remove all stars, except the last one.
How to do that?
WimYogya
retired Dutchman (1944) in Yogyakarta, Indonesia
If you click just the right spot, you will get an empty star field before it turns into the bomb.
Or ... select the track or album and then right-click to select the Rating dialog.  You can select 'no rating' from there.
WimYogya
Found it and made it, when I pinpointed my mouse to the real edge of the box. ;-)
Thanks!
WimYogya
AMDphreak
I noticed the option to right click and select Rating Track and set to Unrated is only available when a single track is selected. I needed to do this for multiple tracks. Think this is pretty simple of a thing to add.
works fine here
Dalinar
I can figure it out on the drop down list of songs under the album. However this "click the right spot" technique doesn't seem to work for me in the tag editor (the tag editor at the bottom of the screen)
also is there a way to pull up the Rating Dialog for multiple selected tracks?
I'm trying to derate an entire album's worth of track ratings in one fell swoop and I can't figure out how except to use the inspector.
