Author Topic: Unhandled Exception - Dragdrop registration did not succeed  (Read 3293 times)
Hypolitus
I'm getting an unhandled exception when I first change the view in the main panel (Albums and Tracks, Artists, Album Covers, etc) after opening the application. This is happening whether I use a hotkey or the menu. It can be avoided by switching to a different Filter and then back again, after which, changing views causes no problems at all, but the problem returns next time the application is opened.
Here are the exception details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: DragDrop registration did not succeed. ---> System.Threading.ThreadStateException: Current thread must be set to single thread apartment (STA) mode before OLE calls can be made. Ensure that your Main function has STAThreadAttribute marked on it.
   at System.Windows.Forms.Control.SetAcceptDrops(Boolean accept)
   at System.Windows.Forms.Control.OnHandleCreated(EventArgs e)
   at System.Windows.Forms.Control.WmCreate(Message& m)
   at #=ql1Mc3YfCdOu3P2CCFrTqZ2uJsf6jTlD9SoYH$IhFEhw=.WndProc(Message& #=q47ICKrxRFWZ4zm9aglk8YA==)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.6.1076.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
MusicBee
    Assembly Version: 3.0.6007.34903
    Win32 Version: 3.0.6007.34903
    CodeBase: file:///C:/Program%20Files%20(x86)/MusicBee/MusicBee.exe
System.Drawing
    Win32 Version: 4.6.1068.2 built by: NETFXREL3STAGE
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    Win32 Version: 4.6.1075.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    Win32 Version: 4.6.1055.0 built by: NETFXREL2
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.6.1055.0 built by: NETFXREL2
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    Win32 Version: 4.6.1067.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Interop.PortableDeviceApiLib
    Assembly Version: 1.0.0.0
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/MusicBee/Interop.PortableDeviceApiLib.DLL
MusicBeeIPod
    Assembly Version: 1.6.0.0
    Win32 Version: 1.6.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/MusicBee/MusicBeeIPod.DLL
mb_TheaterModePlugin
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/MusicBee/Plugins/mb_TheaterModePlugin.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Hypolitus
After a bit more playing around, I've found that it's something to do with the Left Sidebar or the Navigator Panel having been shown. If I open the application with the Left Sidebar on auto-hide and change view without the Left Sidebar having been shown, then I get the unhandled exception. If I flick over to the left and expand the sidebar briefly, then there's no problem subsequently changing view.
could you send me a link to your settings file when its in a state that this happens (help/ support/ view settings)
happycatlol
I just got the same error on version 3.4.8233
I wasn't interacting with the application, just letting it play music while minimized. It then stopped playing music and when I look at the application, it is frozen and unresponsive, eventually throwing an error showing the stack trace above.
Let me know if you want me to send you my settings file.
Since the issue was fixed for the previous user, I suggest you update to the latest version of MB from the first forum topic. It's more than likely the issue has been fixed, but since you're running a version that's more than three years old, you should be using the current version first and before you file any bug reports.
