I have a set of tabs at the top that go directly to my smart lists. One of them is erring out and I can't close them. Trying to close them results in two errors. Also clicking on the one making a new tab. Just want to remove the tabs causing the issue if possible.
http://i.imgur.com/CCbPsRS.pngMusicBee v3.0.6007.34903 (Win10.0), 14 Jun 2016 23:14:
at MusicBee.MusicBeeMain.#=qbJA95CJchT2vqX9FJUFsruSuTCGwsrAbGM73wKJr$kY=(Boolean #=qXV6VbFQEc2UaD5XPsEaFJUVXFv83zXI75aU8LKl5$q0=)
at MusicBee.MusicBeeMain.NavigationHeader.#=qY6TjmMmXs4FOoShzNEEECg==(#=qHjy66$Q_EotOtoDnh41wAUZ4wg$aiJLQgJCzh$vB0hU= #=q6KqGzNkOBd5iOof0nVfsvSNdLDd5ZKRs3DmDlZDfnBI=, Boolean #=qanMjdvRVdKzg8y07IUtqg9VQBea$BUbwrtyUytXVGJE=)
at MusicBee.MusicBeeMain.#=qzPtxBSUvA3HWELUM2fbYeg==(#=qHjy66$Q_EotOtoDnh41wAUZ4wg$aiJLQgJCzh$vB0hU= #=qPUBiuPxbwAOKfKtBXwDBJ1CSSWmNmWJZJGsnFSce7wU=, Boolean #=qhz8jGDL6BcxHNfJoVPMyLI_C40RKE0Jq$qcffcVPR4Y=, #=qro023$IH6qWWa2TjZJMMtQ== #=q50nnNo7kuRv2IBtk_Ti12A==, #=qVne8gnwg7cw6MAH5bSi9cQZWM3fYgBulUFYM6mnYI6c= #=qfQntDJtDvbcu4zKcjLbVn$kuxyxY6_q592Bp6wRugu4=, Boolean #=q9ZjLuo_Y_oOhmK3vvoFVDPZdka47sRxYbbVZgvIMwQU=, #=q8puDxXoqzlM2vbrm_rAfjw$NBhiPzp$PllgNhVbnZxA= #=qrYvPHSuVkHJd45rYAPao3g==, #=qr4OuDmR29AtFN1fyM1wEBCUiAcj0DidNnfQo9aT0AQM=[] #=qc2Zm1FflcY2esiQacWK1stiVRCt2YlpO01JgvN6$xkc=, Boolean #=qVo55VlBRpd9DBZaPNwUXmRLEbofzYQxaJPHXOOtStt8=)
MusicBee v3.0.6007.34903 (Win10.0), 14 Jun 2016 23:27:
System.IO.DirectoryNotFoundException: Could not find a part of the path 'D:\music\MusicBee\Playlists\Folder\.xautopf\Soundtracks.xautopf'.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
at #=qoZ9Fa3qSU3a$jssDjrEg0StcUBf9X_5$Zo3mmfek4eg=.#=qJtK9oShtYX9QKZdFyEkI0g==()
at MusicBee.MusicBeeMain.#=qzCAMK6xYCq19UCqF$TxmPIJlkY$GbUqgFd2QTv6jJTY=.#=qDodk6x9AWvGRrHce$$oEKgpuSbf4sp_urJjTnJ8P1xo=(Boolean #=qo9pBx8rs72f3NiNtRmPnNQ==)
