Author Topic: TM Requests  (Read 86918 times)
  • MB Version: 3.6.9255 P
Perhaps a standout colour can be used instead
For some skins there is not much difference between TrackAndArtistPanel(fg) and TrackAndArtistPanel.HighLight(fg).
Although its easy enough to switch the font to bold for the current playing line, it can mess with the layout because bold requires more width and hence various calculations need to accommodate the possibility that line breaks change.
Would the bold switching work if it was a variable font size panel?
<element type="Lyrics" gammaCorrected="true" xAnchor="#LyricsPanel.Left" x="10" yAnchor="#LyricsPanel.Top" y="20" widthDock="X:#LyricsPanel.Right" width="-10" heightDock="Y:#LyricsPanel.Bottom" height="-5" multiLine="true" align="center" font="Segoe UI" style="Semi-Bold" size="10" minSize="7" fg="191,TrackAndArtistPanel(90)" style2="Black" fg2="204,TrackAndArtistPanel.HighLight(fg)" ></element>
If that's a yes, could it be coded to only work in that circumstance?
I dont really have the time to make difficult changes
Hope this one is not to difficult  :-\
Otherwise, please just add it to the "to do" list when you have time.
Thanks Steven.
Add support for
artistType="GuestArtist"  and  artistType="Remixer"
for use in type="ArtistInfo" panel
combined with
"#GuestArtistStatus", "#RemixerArtistStatus" and "#ConductorStatus" that work like the current"#LyricsStatus" does.
Add support for
combined with
Your request triggered a memory, and I wonder if it is somehow related to what I tried to do with TM's. (a long time ago)
I wanted to have two different artist images displayed at the same time.
One for 'composer' and one for the performing artist.
But I gave up because it seemed not possible and there was also no support for it.
Do you know if that can be accomplished now?
Or would it need something like you are requesting now, but then for 'composer'?
Not 100% sure, but I did a quick run with tags="composer" for the Gallery element and I did get different images back.
But as I got a lot of landscape images back for "Edvard Grieg", I'm not sure what search term MB was using.
Thanks for testing this.
I now recall  that was indeed one of my frustrations in getting that to work also.
Sorry for interrupting, and back to your wish:
Add support for
combined with
Add support for
you want the ArtistInfo panel to only show guest artist or only show remixer when one of those artist types are set?
combined with
and use the #GuestArtistStatus to detect when there is a tagged value in the appropriate field
Yes please.
I just stumbled upon a post of me raising this some 4 years ago:
https://getmusicbee.com/forum/index.php?topic=23452.msg136899#msg136899
So the situation is still the same.
This is what MusicBee thinks what J.S. Bach looked like:
(picture on the right)
Yes, something is definitely off.
A quick Google images search can find so many to choose from:
A quick Google images search can find so many to choose from…
Indeed.
There are even some good photographs of him:
Last Edit: September 11, 2021, 07:44:23 AM by hiccup
With what hiccup and I have been discussing in the previous few posts, I have worked out that the Gallery element only recognises tags="artist".
It doesn't read the track values for tags="composer" or tags="conductor".
 The ArtistPicture element allows "Composer" or "ComposerPref" but that element doesn't accept interval or refreshInterval.  It only changes on new tracks.
So could support be added for the
hard-coded set of names
that "Gallery" could display images for please.
That's probably Composer, Conductor, AlbumArtist, GuestArtist and Remixer.
So could support be added for the…  …that "Gallery" could display images for please.
Ah, you switched on the little lightbulb on my head.
I now understand the reason I could never get it to work in the first place.
I was always trying it with 'gallery'. Never with 'artistpicture'.
Your suggestion seems great.
I am wondering if it wouldn't be feasible to make artist pictures search and retrieval possible on any regular, custom or virtual tag. (that might contain a name)
Last Edit: September 13, 2021, 06:44:59 PM by hiccup
The current default for clicking on any highlighted track in both the "NowPlayingList" and "AlbumTracks" type panels is to PlayNow.
Could we have a per panel override to change that action to QueueNext please.
guestArtist and remixer are in the next plugin update but not
"combined with
"#GuestArtistStatus", "#RemixerArtistStatus" and "#ConductorStatus" that work like the current"#LyricsStatus" does." which is harder to do
"combined with
edit:
this has the fix for the child element alignment overrides
https://www.mediafire.com/file/7ftgbdjrwgs93z8/mb_TheaterModePlugin.zip/file
Did the above plugin update have the guestArtist and remixer updates in it?
If so, I don't think they have been added into the hard-coded tag availability list:
the theatre mode plugin works off a hard-coded set of names
"artist"
"title"
"trackartistandtitle"
"album"
"albumandyear"
"albumartist"
"bpm"
"composer"
"comment"
"conductor"
"custom1".."custom16"
"discno"
"disccount"
"discandtrackno"
"duration"
"genre"
"genrecategory"
"grouping"
"kind"
"mood"
"occasion"
"playcount"
"publisher"
"quality"
"rating"
"ratingalbum"
"ratinglove"
"speaker"
"skipcount"
"tempo"
"trackno"
"trackcount"
"language"
"work"
"showmovement"
"movement"
"movementno"
"originalartist"
"originaltitle", "originalalbum"
"originalyear"
"instrumentsperformers"
"virtual1".."virtual25" (will add the missing ones)
"year"
"year(yyyy)", "year (yyyy)"
