Author Topic: No way back  (Read 2251 times)
koe!k
There is no possibility to leave this Window:
koe!k
No idea?
I'm using 10,1" screen (1280x800) with scaling 125%
Only Task killing to going back?
koe!k
This is the same window in MB 2.5
(at the same notebook)
Alt + F4 should close that panel.
For you to make edits in the preferences panel, it would probably be best to temporarily set scaling to 100%.
koe!k
Oh yes, Alt+F4.
Changing the scaling is a little bit laborious.
i have put in some crude handling so at least the buttons and caption bar will be visible. The panel layout overrides section would be partially obscured.
Its in the next v3 patch update
koe!k
