Author Topic: can't change the costume color for highlighted text  (Read 2635 times)
ultravigo
i just can't change the customize color for sync lyrics...
the colour setting is ignored when lyrics are overlaid onto a picture ie. the text is always white drawn with a shadow effect to maximise the contrast
ultravigo
so is there any option for not  getting color setting ignored?
its not ignored if the lyrics are not overlaid onto the picture
ultravigo
just how can i change the color for highlighted text...can you please make it clear?
ultravigo
well i did it but now the track details is gone..is it  a con while displaying customize highlighted text?
i have changed the behavior to respect that setting in all cases:
unzip into the folder MB is installed
