Author Topic: Edit config file so Initial key tag looks for "INITIALKEY"  (Read 3258 times)
SHODAN
in the configuration.xml, 'Initial Key' is looking for "INITIAL KEY" in FLAC files. FLAC files use "INITIALKEY" without a space. the work-around at the moment is to create a new custom tag for FLAC keys, or edit the config file.
Last Edit: May 12, 2016, 09:19:20 PM by SHODAN
c-Row
Just bumping this since I just ran into this issue which is still not fixed two years later.
karbock
Meanwhile, Configuration.xml has been adapted.
In a version that I had archived on 24 Nov 2020:
<Tag id="Initial Key" id3v23="TKEY" id3v24="TKEY" wma="WM/InitialKey" vorbisComments="INITIAL KEY" mpeg="INITIALKEY" ape2="InitialKey" />
In a later version, archived on 28 Jul 2024:
<Tag id="Initial Key" id3v23="TKEY" id3v24="TKEY" wma="WM/InitialKey" vorbisComments="INITIALKEY" mpeg="INITIALKEY" ape2="InitialKey" />
