-I play an album that's not in the library in the "Now Playing" playlist
-After finishing, I remove the entire album
-Go to Windows Explorer to remove the folder the album is in
-Try to delete, but Windows says that it's being used in another program
-Close MB
-Attempt to remove the folder, and successfully goes to the Recycle Bin.
First wish: When one removes all of the tracks in the "Now Playing" playlist, can there be an option to not display the confirmation each time one does this?
Second wish: When one removes all of the tracks in the "Now Playing" playlist, can MB clear all of the info it's storing so one can remove the album from Windows Explorer?
Pretty sure both are intentional behavior, so I'll put it here
