Hi, thank you! I worked with the settings you described the best that I could, using a "DX50 Music" folder as a virtual device, and a test playlist called "0. NEW Genesis".
What I ended up with is as follows:
a. Inside "DX50 Music" device (folder), I have two parent folders: Music and Playlists. Music is empty.
b. Inside "Playlists" I have two things:
1. An m3u file for my playlist, correctly titled "0. NEW Genesis.m3u"
2. A subfolder called "0. NEW Genesis" containing all the song files associated with the playlists (correctly).
c. Here's the problem: when opening the .m3u in Notepad, I have the following string for each song (first is included here as an example):
.\0. NEW Genesis\001-Genesis-10 Match Of The Day.mp3
What I need for the player to work is only the name of the song, nothing more, so:
Also, if the .m3u can be in the SAME folder as the song files, that's what I need. I can do that manually, of course, but ideally I can set MusicBee to drop the .m3u, containing the name of the songs in the playlists only with no directories, along with all the relevant song files in ONE folder named for the playlist... and then do that for every playlist in a batch command, sending all the separate folders (with song files and .m3u) to the virtual device.
It feels close, thanks for your help to get this right!
