Author Topic: 3.0 RC2: Very Limited Access to Music  (Read 5960 times)
dataGuy
Just upgraded to MusicBee 3.0.5954 on Windows 7. I can only access music from "Auto DJ". If I click on "Music" or a playlist, MusicBee terminates. If a track is playing and I select "Now Playing", "History" or "Music Explorer" MusicBee terminates. If a track is not playing, I can open those items, in a new tab, but the tab is blank; with the exception of "History", selecting open in a new tab still causes MusicBee to terminate. I can select "Inbox" but the list is empty; which is the correct function because I typically don't move files to the inbox.
I turned off Playlist manager thinking that was why I couldn't access a playlist but no change; MusicBee still terminates when selecting a playlist. Right clicking, a playlist, and selecting "Play Now" freezes the playback and opens a dialog box (MusicBee has stopped working) with the option to close the program.
Right clicking "Music" and selecting "Play library shuffled" or "Open in a new tab" MusicBee terminates. Same result when a track is playing or a track is not playing.
In general, any way I can think of to access a music track outside of "Auto DJ" causes MusicBee to stop and exit me to Windows. I downloaded and installed 3.0RC2 twice to make sure it wasn't a corrupted file issue.
Take a look at the error log: Help > Support > View Error Log and look for entries around the time MB terminates.  Copy those entries and paste them here.
dataGuy
I was just looking through the log. The newest entries are from a couple of weeks ago (related to coping files to an iPod. So, despite all the sudden exits (which likely don't give time to post a log entry) and the MusicBee has stopped dialogs  nothing is posted in the error log.
Hmmm ... where are you downloading MB from?  The MB website/forum?  Or another site?  If the latter, please try downloading v3 RC 2 from here: http://getmusicbee.com/forum/index.php?topic=17326.msg109842#new
dataGuy
The first download was from my update alert service. The second time I came to the forum to make sure I had the latest.
Thanks for giving my problem some thought... I know this must be weird since no one else is reporting this kind of issue. Everything was working fine under 2.5. I'm guessing the solution is to roll back to the prior version.
have a look in the windows event log which will have additional information on application crashes.
dataGuy
There are MusicBee errors in the event log. They don't look too helpful. Here is the last entry:
General:
Faulting application name: MusicBee.exe, version: 3.0.5954.32859, time stamp: 0x5717b972
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc00000fd
Fault offset: 0x09713e53
Faulting process id: 0x860
Faulting application start time: 0x01d19cab74aaa2f9
Faulting application path: C:\Program Files (x86)\MusicBee\MusicBee.exe
Faulting module path: unknown
Report Id: 317dbb18-089f-11e6-80c4-90fba6e44605
Detail:
MusicBee.exe
   3.0.5954.32859
   5717b972
   unknown
   0.0.0.0
   00000000
   c00000fd
   09713e53
   860
   01d19cab74aaa2f9
   unknown
i suggest you temporarily rename your settings files which are in the same AppData folder as the error log:
MusicBeeSettings.ini
MusicBee3Settings.ini
StartupSettings.ini
that way you are starting using default settings
if MB starts behaving normally i would need a zip of those files and also MusicBeeLibrary.mbl in the Music\MusicBee folder
edit:
also try temporarily renaming the Plugin folder in the musicbee application directory
Last Edit: April 22, 2016, 05:14:00 PM by Steven
dataGuy
Renamed the files - same issue. So not a configuration problem I guess. Not sure if it is related but after the install MB went back to a default skin; which I haven't changed.
Update: renamed the plugins folder - no impact.
btw - I have rebooted Windows on the chance that would help(before I reported the problem) - it didn't. I have also ran my registry cleaner but that also didn't change anything.
Last Edit: April 22, 2016, 05:33:12 PM by dataGuy
in that case i wont be able to help any further. It is a very strange issue.
If you rename the files back, and replace MusicBee.exe with the v2.5 exe then you should be able to use it with your old settings
dataGuy
That's what I was afraid of. I do feel better that it wasn't some stupid user error. ;-)
Thanks for your time. I'll try again with the next RC. Thanks again....
dataGuy
Two additional data points:
I tried doing a search, as soon as I started typing MB terminated. It is as if this install could not handle looking at storage except through Auto DJ. My data files are stored on an external USB drive (which works fine under 2.5).
I downloaded the last 2.5 version. I was able to install MB with no issues.
let me know if you are happy to run a debug version. It may take a few attempts to track down where the error occurs
dataGuy
I'm be happy to help. Let me know what I need to do to run the debug....
http://www.mediafire.com/download/er7oqo690be07jo/MusicBeeDebugLoad.zip
unzip into the folder MB is installed (keep a copy of your existing musicbee.exe)
after MB has crashed and you have restarted it, open the error log (help/ support/ view error log) and send me the set of entries at the end
