Hi. First post to the forum after many years of using MB. Best application on my computer! Thank you so much.
I finally ran into something that does not work like I would expect. I have 1,500+ albums with artwork embedded in the tag, which is great. Only problem is that I now own a player that will not read artwork tags and instead needs a cover.jpg to display art (it's in my truck, so I can't get rid of it). So, I run Search Internet for Picture with all of the albums selected in Artwork view and every track is listed, but unchecked because MB does not think I need to get artwork. I can check each and everyone of the 20,000 plus tracks, but I do not have the mental stamina to do so ;) Ctrl+A does nothing and shift select does not work either. A top checkbox in the header row is what I would expect to see, but there is nothing there. Any thoughts? Can a check-all check box be added in a future release? Thanks!
