Author Topic: Left Sidebar showing when I dragging from library to playing tracks  (Read 3032 times)
felipe
Whenever I try to drag a song to the playlist, the left sidebar appears over the playlist.
While dragging:
After dragging:
Even left sidebar marked as hidden:
what version are you using. If you are using recent versions then the left sidebar should not pop up when dragging if its configured as hidden
can you send me a link to your settings file (help/ support/ view settings)
i still cannot reproduce the issue even with your settings. If you click Help/ About what version does it say?
edit:
i do notice that the left sidebar is not set to hidden in other tabs. Perhaps you were dragging in those tabs?
Last Edit: April 14, 2016, 07:42:25 PM by Steven
felipe
The same behavior happened in my secondary computer, which only has a single tab. The behavior happens when I'm dragging the song and move the mouse toward the left. I don't  understand how hide the left sidebar for each tab.
