*better elements for the tag editor
*alternate Tabs Bar background when the library header bar is hidden
The Tag Editor is one that has bugged me since I first started skinning for MusicBee. Some of the pieces have their own elements, and some are linked to elements in other panels, which creates inconsistencies.
Examples (looking at Mellon Remix, if it matters):
*Most of the borders in the tag editor are controlled by "InputPanel.Default", but there are a few spots that use "Controls.FaintLine". Those only exist on some tabs, and the contrast color I use for Preferences looks weird in the Tag Editor. Oh, and the border between the background and "Toolbar.Body" is controlled by something else, I can't even figure out what right now (neither fg or bdr on Toolbar.Body has an effect).
*The fact that ALL the tab borders are controlled by "InputPanel.Default" means that you can't have, for instance, a different border on the inactive tabs.
*Likewise, both the background color and the active tab color are controlled by "InputPanel.Default", so you can't have a contrast between the background and the tab.
Does EditPanel.Default even do anything anymore? I have it marked as "Tag Editor Window" on the wiki but I don't see any effect when I edit it.
