I would like to see a checkbox under the podcasts heading: "[ ] make podcasts compatible with iTunes". If this option was checked, MB would make the following 3 changes for all tracks in the podcast library:
-create an ITUNES PODCAST [PCST] tag, with a value of 1.
-copy the value from ORIGIN [WOAS] into a new tag called ITUNES SUBSCRIPTION [WFED].
-convert the EPISODE DATE [TDRL] value into the format yyyy-MM-dd HH:mm:ss.
Tracks within the MB podcast library would then be fully compatible with the iTunes library.
