Author Topic: Odd Problem with "Show Files with Inconsistent tags" Filter  (Read 6412 times)
dbisping
Ive just started using the Show Files with Inconsistent Tags and it's proving a big help finding errors in my current library, However I am seeing that it often is telling me that an album is Missing Track 1. If I go into the folder and check  the Track in Question is present. This is happening on a large percentage of the albums, I've checked for obvious errors but not yet been able to find the cause.
This is happening on both .2.5.5721 & 3.0.5909, Any clue what might be causing this to occur?
can you either post a screenshot showing the Tags tab for the first track in the album and the second, or alternatively PM me a link to a zip of both those files
dbisping
I've take some screen shots tomorrow and upload them to dropbox tomorrow, Many Thanks!
fabulario
Exactly the same problem here.
The info about he missing track (In Spanish in my program)
Track 1
Track 2
I'm using v3 and the last updates.
Last Edit: March 16, 2016, 11:21:03 PM by fabulario
dbisping
I'll also do some screendumps as well tomorrow, but have found some more info.
I think 2.5 might be reporting correct information, I can't double check this till tomorrow but it does look correct I think
3.0 I think fails on any multi CD where the CD number is >1 ie Disc 1 of 3 it detects track 1 correctly, but Disc 2 of 3 or 3 of 3 it fails to detect Track 1 and says it's missing, if the Disc Number  is left empty it also seems to work
I am also getting a problem withb Null Album Artists as well, not sure if this is my problem tho
track 1 from disc 2 is missing according to the first screenshot.
you are then showing the 1st and 2nd tracks from disc 1 but that is not the issue being reported
fabulario
Oops!!
Track 1
Track 2
After reading this, I've checked my library and yes, except for a couple of cases that I will review better, this happens when the album has more than one CD.
the bug with the first track of the 2nd disc is fixed for the next update
dbisping
Is it possible to download this version yet?, I am trying to get my head around an issue with the Album Artist not matching the Artists, I am 99% sure this is my problem but I don;t see it in 2.5
dbisping
I quite understand, its just I am not getting the issue reported in 2.5 but I do in 3.0, but as i said I am 99% sure its my problem and not a issue actually with 3.0
OK, so what's your Album Artist problem with v3? If needed, post screenshots.
