There was nothing in errorlog.dat (the last item in there was "not found" message regarding a file I deleted from inbox). Here's information from Windows event viewer:
Event 1025, .Net Runtime error:
Application: MusicBee3.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: exception code c0000005, exception address 0A8402F4
Event 1000, Application Error:
Faulting application name: MusicBee3.exe, version: 3.0.5904.39256, time stamp: 0x56d60e7e
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0x00000000
Fault offset: 0x00000000
Faulting process id: 0x5900
Faulting application start time: 0x01d174cfcbfdd893
Faulting application path: C:\Program Files (x86)\MusicBee\MusicBee3.exe
Faulting module path: unknown
Report Id: f4980fd5-e0cc-11e5-82ff-dc0ea1f07fc7
Windows Error Reporting:
Fault bucket 625901704, type 25
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: MusicBee3.exe
P2: 3.0.5904.39256
P3: 56d60e7e
P4: StackHash_d430
P5: 0.0.0.0
P6: 00000000
P7: 00000000
P8: 00000000
P9:
P10:
C:\Users\Home\AppData\Local\Temp\WERD0FD.tmp.WERInternalMetadata.xml
These files may be available here:
C:\Users\Home\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_MusicBee3.exe_e920109db625276677b288c03bad88c1474d51_6d1bad28
Analysis symbol:
Rechecking for solution: 0
Report Status: 0
AppCrash_MusicBee3.exe_e920109db625276677b288c03bad88c1474d51_6d1bad28:
Version=1
EventType=APPCRASH
EventTime=131014342597604675
ReportType=2
Consent=1
UploadTime=131014342598674737
ReportIdentifier=f4980fd6-e0cc-11e5-82ff-dc0ea1f07fc7
IntegratorReportIdentifier=f4980fd5-e0cc-11e5-82ff-dc0ea1f07fc7
WOW64=1
Response.BucketId=625901704
Response.BucketTable=25
Response.type=4
Sig[0].Name=Application Name
Sig[0].Value=MusicBee3.exe
Sig[1].Name=Application Version
Sig[1].Value=3.0.5904.39256
Sig[2].Name=Application Timestamp
Sig[2].Value=56d60e7e
Sig[3].Name=Fault Module Name
Sig[3].Value=StackHash_d430
Sig[4].Name=Fault Module Version
Sig[4].Value=0.0.0.0
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=00000000
Sig[6].Name=Exception Code
Sig[6].Value=00000000
Sig[7].Name=Exception Offset
Sig[7].Value=00000000
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7601.2.1.0.256.1
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=d430
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=d4301ef7a2395458c9199aaa255c8858
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=a3a4
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=a3a4266342ee1e63a6ae3aeb3ebef71c
UI[2]=C:\Program Files (x86)\MusicBee\MusicBee3.exe
UI[3]=MusicBee has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution and close the program
UI[6]=Check online for a solution later and close the program
UI[7]=Close the program
LoadedModule[0]=C:\Program Files (x86)\MusicBee\MusicBee3.exe
LoadedModule[1]=C:\Windows\SysWOW64\ntdll.dll
LoadedModule[2]=C:\Windows\SYSTEM32\MSCOREE.DLL
LoadedModule[3]=C:\Windows\syswow64\KERNEL32.dll
LoadedModule[4]=C:\Windows\syswow64\KERNELBASE.dll
LoadedModule[5]=C:\Windows\syswow64\ADVAPI32.dll
LoadedModule[6]=C:\Windows\syswow64\msvcrt.dll
LoadedModule[7]=C:\Windows\SysWOW64\sechost.dll
LoadedModule[8]=C:\Windows\syswow64\RPCRT4.dll
LoadedModule[9]=C:\Windows\syswow64\SspiCli.dll
LoadedModule[10]=C:\Windows\syswow64\CRYPTBASE.dll
LoadedModule[11]=C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
LoadedModule[12]=C:\Windows\syswow64\SHLWAPI.dll
LoadedModule[13]=C:\Windows\syswow64\GDI32.dll
LoadedModule[14]=C:\Windows\syswow64\USER32.dll
LoadedModule[15]=C:\Windows\syswow64\LPK.dll
LoadedModule[16]=C:\Windows\syswow64\USP10.dll
LoadedModule[17]=C:\Windows\system32\IMM32.DLL
LoadedModule[18]=C:\Windows\syswow64\MSCTF.dll
LoadedModule[19]=C:\Windows\SysWOW64\nvinit.dll
LoadedModule[20]=C:\Windows\system32\VERSION.dll
LoadedModule[21]=C:\Program Files (x86)\NVIDIA Corporation\CoProcManager\detoured.dll
LoadedModule[22]=C:\Program Files (x86)\NVIDIA Corporation\CoProcManager\nvd3d9wrap.dll
LoadedModule[23]=C:\Windows\syswow64\SETUPAPI.dll
LoadedModule[24]=C:\Windows\syswow64\CFGMGR32.dll
LoadedModule[25]=C:\Windows\syswow64\OLEAUT32.dll
LoadedModule[26]=C:\Windows\syswow64\ole32.dll
LoadedModule[27]=C:\Windows\syswow64\DEVOBJ.dll
LoadedModule[28]=C:\Program Files (x86)\NVIDIA Corporation\CoProcManager\nvdxgiwrap.dll
LoadedModule[29]=C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
LoadedModule[30]=C:\Windows\system32\MSVCR120_CLR0400.dll
LoadedModule[31]=C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\d1265d6159ea876f9d63ea4c1361b587\mscorlib.ni.dll
LoadedModule[32]=C:\Windows\system32\uxtheme.dll
LoadedModule[33]=C:\Program Files (x86)\RocketDock\RocketDock.dll
LoadedModule[34]=C:\Windows\syswow64\PSAPI.DLL
LoadedModule[35]=C:\Program Files (x86)\Lenovo\Onekey Theater\ActiveDetect32.dll
LoadedModule[36]=C:\Program Files (x86)\Lenovo\Onekey Theater\WindowsApiHookDll32.dll
LoadedModule[37]=C:\Windows\assembly\NativeImages_v4.0.30319_32\System\d18e2115a3270f89663fce831547f534\System.ni.dll
LoadedModule[38]=C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Drawing\fe41e3eae34ac29f3c1f03a03d8aa1af\System.Drawing.ni.dll
LoadedModule[39]=C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll
LoadedModule[40]=C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\ac49b0362a9648df9d2f437d27ff54ff\System.Windows.Forms.ni.dll
LoadedModule[41]=C:\Windows\Microsoft.NET\Framework\v4.0.30319\nlssorting.dll
LoadedModule[42]=C:\Windows\syswow64\shell32.dll
LoadedModule[43]=C:\Windows\system32\dwmapi.dll
LoadedModule[44]=C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.19061_none_72d6d48d86649709\gdiplus.dll
LoadedModule[45]=C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Core\c61bafa9d029e3f2bf83bd5af3f1f5ac\System.Core.ni.dll
LoadedModule[46]=C:\Windows\assembly\NativeImages_v4.0.30319_32\Microsoft.V9921e851#\80cf584865ab5a58a959cf94e087d073\Microsoft.VisualBasic.ni.dll
LoadedModule[47]=C:\Windows\system32\CRYPTSP.dll
LoadedModule[48]=C:\Windows\system32\rsaenh.dll
LoadedModule[49]=C:\Windows\system32\RpcRtRemote.dll
LoadedModule[50]=C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Configuration\908075c4922acdf834c67ac802814c9d\System.Configuration.ni.dll
LoadedModule[51]=C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Xml\3d6ee4ffbd9a86ac1e7b01800b6fe9c7\System.Xml.ni.dll
LoadedModule[52]=C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_41e855142bd5705d\comctl32.dll
LoadedModule[53]=C:\Windows\system32\WindowsCodecs.dll
LoadedModule[54]=C:\Windows\system32\apphelp.dll
LoadedModule[55]=C:\Windows\syswow64\CLBCatQ.DLL
LoadedModule[56]=C:\Windows\system32\EhStorShell.dll
LoadedModule[57]=C:\Windows\system32\PROPSYS.dll
LoadedModule[58]=C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18837_none_ec86b8d6858ec0bc\COMCTL32.dll
LoadedModule[59]=C:\PROGRA~2\MICROS~2\Office14\GROOVEEX.DLL
LoadedModule[60]=C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCR90.dll
LoadedModule[61]=C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCP90.dll
LoadedModule[62]=C:\Windows\WinSxS\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_51cd0a7abbe4e19b\ATL90.DLL
LoadedModule[63]=C:\PROGRA~2\COMMON~1\MICROS~1\OFFICE14\Cultures\office.odf
LoadedModule[64]=C:\PROGRA~2\MICROS~2\Office14\1033\GrooveIntlResource.dll
LoadedModule[65]=C:\Windows\system32\ntshrui.dll
LoadedModule[66]=C:\Windows\system32\srvcli.dll
LoadedModule[67]=C:\Windows\system32\cscapi.dll
LoadedModule[68]=C:\Windows\system32\slc.dll
LoadedModule[69]=C:\Windows\system32\IconCodecService.dll
LoadedModule[70]=C:\Program Files (x86)\MusicBee\bass.dll
LoadedModule[71]=C:\Windows\system32\MSACM32.dll
LoadedModule[72]=C:\Windows\system32\WINMM.dll
LoadedModule[73]=C:\Windows\system32\explorerframe.dll
LoadedModule[74]=C:\Windows\system32\DUser.dll
LoadedModule[75]=C:\Windows\system32\DUI70.dll
LoadedModule[76]=C:\Windows\system32\ntmarta.dll
LoadedModule[77]=C:\Windows\syswow64\WLDAP32.dll
LoadedModule[78]=C:\Windows\syswow64\profapi.dll
LoadedModule[79]=C:\Windows\system32\LINKINFO.dll
LoadedModule[80]=C:\Windows\SysWOW64\gameux.dll
LoadedModule[81]=C:\Windows\SysWOW64\XmlLite.dll
LoadedModule[82]=C:\Windows\syswow64\CRYPT32.dll
LoadedModule[83]=C:\Windows\syswow64\MSASN1.dll
LoadedModule[84]=C:\Windows\SysWOW64\wer.dll
LoadedModule[85]=C:\Windows\System32\Wpc.dll
LoadedModule[86]=C:\Windows\syswow64\USERENV.dll
LoadedModule[87]=C:\Windows\System32\wevtapi.dll
LoadedModule[88]=C:\Windows\System32\msxml6.dll
LoadedModule[89]=C:\Windows\System32\bcrypt.dll
LoadedModule[90]=C:\Windows\system32\samcli.dll
LoadedModule[91]=C:\Windows\system32\SAMLIB.dll
LoadedModule[92]=C:\Windows\system32\netutils.dll
LoadedModule[93]=C:\Program Files (x86)\MediaMonkey\MMHelper.dll
LoadedModule[94]=C:\Program Files\Lenovo\Bluetooth Software\SysWOW64\BtMmHook.dll
LoadedModule[95]=C:\Program Files (x86)\WinRoll\winroll.dll
LoadedModule[96]=C:\Windows\system32\dsound.DLL
LoadedModule[97]=C:\Windows\system32\POWRPROF.dll
LoadedModule[98]=C:\Windows\System32\MMDevApi.dll
LoadedModule[99]=C:\Windows\system32\AUDIOSES.DLL
LoadedModule[100]=C:\Program Files (x86)\MusicBee\basscd.dll
LoadedModule[101]=C:\Program Files (x86)\MusicBee\Plugins\MB_MiniLyrics.dll
LoadedModule[102]=C:\Program Files (x86)\MusicBee\bassmix.dll
LoadedModule[103]=C:\Windows\system32\PortableDeviceApi.dll
LoadedModule[104]=C:\Program Files (x86)\MusicBee\bass_winamp.dll
LoadedModule[105]=C:\Program Files (x86)\MusicBee\Plugins\in_mod-2.2.10b29.dll
LoadedModule[106]=C:\Windows\syswow64\comdlg32.dll
LoadedModule[107]=C:\Program Files (x86)\MusicBee\bassflac.dll
LoadedModule[108]=C:\Windows\System32\shdocvw.dll
LoadedModule[109]=C:\Windows\SysWOW64\thumbcache.dll
LoadedModule[110]=C:\Windows\system32\SearchFolder.dll
LoadedModule[111]=C:\Windows\SysWOW64\actxprxy.dll
LoadedModule[112]=C:\Windows\system32\rasapi32.dll
LoadedModule[113]=C:\Windows\system32\rasman.dll
LoadedModule[114]=C:\Windows\syswow64\WS2_32.dll
LoadedModule[115]=C:\Windows\syswow64\NSI.dll
LoadedModule[116]=C:\Windows\system32\rtutils.dll
LoadedModule[117]=C:\Windows\system32\mswsock.dll
LoadedModule[118]=C:\Windows\System32\wshtcpip.dll
LoadedModule[119]=C:\Windows\System32\wship6.dll
LoadedModule[120]=C:\Windows\system32\winhttp.dll
LoadedModule[121]=C:\Windows\system32\webio.dll
LoadedModule[122]=C:\Windows\System32\StructuredQuery.dll
LoadedModule[123]=C:\Windows\System32\Secur32.dll
LoadedModule[124]=C:\Windows\system32\credssp.dll
LoadedModule[125]=C:\Windows\system32\IPHLPAPI.DLL
LoadedModule[126]=C:\Windows\system32\WINNSI.DLL
LoadedModule[127]=C:\Windows\system32\dhcpcsvc.DLL
LoadedModule[128]=C:\Windows\system32\dhcpcsvc6.DLL
LoadedModule[129]=C:\Windows\system32\DNSAPI.dll
LoadedModule[130]=C:\Program Files (x86)\Bonjour\mdnsNSP.dll
LoadedModule[131]=C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
LoadedModule[132]=C:\Windows\system32\rasadhlp.dll
LoadedModule[133]=C:\Windows\System32\fwpuclnt.dll
LoadedModule[134]=C:\Windows\SysWOW64\schannel.dll
LoadedModule[135]=C:\Windows\system32\ncrypt.dll
LoadedModule[136]=C:\Windows\SysWOW64\bcryptprimitives.dll
LoadedModule[137]=C:\Windows\system32\GPAPI.dll
LoadedModule[138]=C:\Program Files (x86)\TCB Networks\StrokeIt\mhook.dll
LoadedModule[139]=C:\Program Files (x86)\MusicBee\libFLAC.dll
LoadedModule[140]=C:\Windows\system32\l3codecp.acm
LoadedModule[141]=C:\Program Files (x86)\MusicBee\bass_fx.dll
LoadedModule[142]=C:\Program Files (x86)\MusicBee\basswasapi.dll
LoadedModule[143]=C:\Program Files (x86)\MusicBee\MusicBeeBass.dll
LoadedModule[144]=C:\Windows\system32\avrt.dll
LoadedModule[145]=C:\Windows\system32\WMVCore.dll
LoadedModule[146]=C:\Windows\system32\WMASF.DLL
LoadedModule[147]=C:\Program Files (x86)\MusicBee\basswma.dll
LoadedModule[148]=C:\Program Files (x86)\MusicBee\bass_aac.dll
LoadedModule[149]=C:\Windows\system32\mlang.dll
LoadedModule[150]=C:\Windows\system32\msdmo.dll
LoadedModule[151]=C:\Windows\SysWOW64\WMADMOD.DLL
LoadedModule[152]=C:\Windows\system32\mfplat.DLL
LoadedModule[153]=C:\Windows\syswow64\api-ms-win-downlevel-advapi32-l1-1-0.dll
LoadedModule[154]=C:\Windows\syswow64\api-ms-win-downlevel-shlwapi-l1-1-0.dll
LoadedModule[155]=C:\Windows\syswow64\api-ms-win-downlevel-user32-l1-1-0.dll
LoadedModule[156]=C:\Windows\syswow64\api-ms-win-downlevel-version-l1-1-0.dll
LoadedModule[157]=C:\Windows\syswow64\api-ms-win-downlevel-normaliz-l1-1-0.dll
LoadedModule[158]=C:\Windows\syswow64\normaliz.DLL
LoadedModule[159]=C:\Windows\syswow64\iertutil.dll
LoadedModule[160]=C:\Windows\SysWOW64\urlmon.dll
LoadedModule[161]=C:\Windows\syswow64\api-ms-win-downlevel-ole32-l1-1-0.dll
LoadedModule[162]=C:\Windows\syswow64\WININET.dll
LoadedModule[163]=C:\Program Files (x86)\Common Files\microsoft shared\ink\tiptsf.dll
LoadedModule[164]=C:\Windows\system32\api-ms-win-downlevel-advapi32-l2-1-0.dll
LoadedModule[165]=C:\Windows\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll
LoadedModule[166]=C:\Windows\system32\msls31.dll
LoadedModule[167]=C:\Program Files (x86)\Internet Explorer\ieproxy.dll
LoadedModule[168]=C:\Windows\system32\ieframe.DLL
LoadedModule[169]=C:\Windows\system32\api-ms-win-downlevel-shell32-l1-1-0.dll
LoadedModule[170]=C:\Windows\system32\MPR.dll
LoadedModule[171]=C:\Windows\System32\drprov.dll
LoadedModule[172]=C:\Windows\System32\WINSTA.dll
LoadedModule[173]=C:\Windows\System32\ntlanman.dll
LoadedModule[174]=C:\Windows\System32\davclnt.dll
LoadedModule[175]=C:\Windows\System32\DAVHLPR.dll
LoadedModule[176]=C:\Windows\system32\wkscli.dll
LoadedModule[177]=C:\Windows\syswow64\WINTRUST.dll
LoadedModule[178]=C:\Windows\system32\zipfldr.dll
LoadedModule[179]=C:\Windows\system32\NetworkExplorer.dll
LoadedModule[180]=C:\Windows\system32\windowscodecsext.dll
LoadedModule[181]=C:\Windows\system32\mfreadwrite.DLL
LoadedModule[182]=C:\Windows\System32\mf.dll
LoadedModule[183]=C:\Windows\System32\ATL.DLL
LoadedModule[184]=C:\Windows\System32\ksuser.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
State[1].Key=DataRequest
State[1].Value=Bucket=625901704/nBucketTable=25/nResponse=1/n
FriendlyEventName=Stopped working
ConsentKey=APPCRASH
AppName=MusicBee
AppPath=C:\Program Files (x86)\MusicBee\MusicBee3.exe
