Author Topic: Ampersand(&) breaking weblinks despite being correctly escpaed.  (Read 1576 times)
awildturtok
The Links feature seems to be having problems with ampersands, when opening a custom youtube link of the following format
https://www.youtube.com/results?search_type=search_videos&search_query=<Artist> <Title>
With the Artist "King Gizzard & The Lizard Wizard" the following url is opened(Where one can clearly see, that the & is not escpaed like the space character)
https://www.youtube.com/results?search_type=search_videos&search_query=King%20Gizzard%20&%20The%20Lizard%20Wizard%20I%27m%20Not%20In%20Your%20Mind&search_sort=relevance&search_category=0&page=
But the search is only done for "King Gizzard" similarily with "La Monte Young & Marian Zazeela". The same problem occurs with Bandcamp Links of the following format:
https://bandcamp.com/search?q=<Album Artist>
It seems like you are forgetting to escape the ampersand, maybe the .NET method ignores it?
That's an issue I've run into, as well.
You can work around it with a function.  Just substitute this in place of <Artist>.  You can do the same with other tags, just change <Artist> to whatever tag it is.
 $Replace(<Artist>,&,)
