MusicBee v3.0.5895.37007 (Win10.0), 22 feb 2016 18:22:System.NullReferenceException: Object reference not set to an instance of an object. at MusicBee.MusicBeeMain.#=q6hPdjSJpzIAUBdy7uiDX7g==.#=qDLoU8b5v0jH1NS_cCRlvMjZWzrwSFb4YBs_3rCFWUFc=(Object #=qhA70CbiiRJfEnvZn_T_dLQ==, ToolStripDropDownClosingEventArgs #=qrl$a7CFSKozR4D1saA3SOQ==) at System.Windows.Forms.ToolStripDropDown.OnClosing(ToolStripDropDownClosingEventArgs e) at System.Windows.Forms.ToolStripDropDown.SetVisibleCore(Boolean visible) at System.Windows.Forms.ContextMenuStrip.SetVisibleCore(Boolean visible) at System.Windows.Forms.ToolStripDropDown.OnItemClicked(ToolStripItemClickedEventArgs e) at System.Windows.Forms.ToolStrip.HandleItemClick(ToolStripItem dismissingItem) at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e) at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e) at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met) at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ToolStrip.WndProc(Message& m) at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
