I went through the link provided and understood that there is no way to have universal column setting in MB. You have to set the desired columns separately for each node on the left navigation pane (library, playlists, computer, device). In addition, each node under library (such as Music, Podcasts, Audiobooks, Radio, Inbox, History, Search results) has its own set of columns. New static playlists (created by the user) and other auto-playlists (till they are not modified by the user) derive their settings from the ‘Auto DJ’ playlist.
I wish the developer adds a setting/preference in the next version so that a particular column setting can be applied 'universally' in MB.
Just one more query. If a user has modified the columns of an auto-playlist (such that it no longer derives its setting from Auto-DJ), is there any way to undo/reset it so that it will again reflect the settings of Auto DJ.
