Author Topic: F2 not editing Disk-Track# (3.0.5874)  (Read 1588 times)
jfhopkin
In the track list, F2 to edit the value works on all columns I've tried other than "Disk-Track#", where it has no effect.
I think that's expected as that field is generated from Disk# and Track# field. Manual editing works for both fields.
jfhopkin
True, although it could work as an input field too, with crude parsing. A number on its own would be a track number, two numbers with a separator could be disk and track.
While manual editing does work, often I find that an album has no track data, which means opening up the edit window, focussing and overtyping the track number, then closing the window - once for each track. It would be nice if we could just edit the field in situ.
